Brief Description: Horizontal stabilizer tip installation
Tonight was a repeat of last night except for the right side of the horizontal stabilizer. I riveted the tail tip rib into place and cut the fiberglass tip down to size using a dremel tool with a cutoff blade. Installed tip and drilled hole. Right side is ready to be prepped for paint.
