Brief Description: Vertical stabilizer tip installation
Tonight was a repeat of last night except for the vertical stabilizer. I riveted the vertical tip rib into place and cut the fiberglass tip down to size using a dremel tool with a cutoff blade. I still need to drill this one before I start to prep for painting.
