Installed root rib, rib 1 and 2, and rear spar. Had a good day finishing up getting the ribs all installed. I did a lot of drilling, deburring, and riveting to finish the rib work on the right wing. After I drilled a few holes through the attachment plates into the root ribs, I decided it would be easier to just remove the attachment plates to finish the drilling and riveting. This worked out very well as it would have been very hard to drill and rivet these holes that close to the spare. With all the ribs attached to the spar, I was able to finish attaching the rear spar. I am now ready to star putting the aft skins on. I noticed that the camera I have been using has been putting a date on the photos and it isn't even correct. Nice! :) I think I will just turn that function off.
