Sonex N367SX
Date:  12-29-2010
Number of Hours:  1.00
Manual Reference:  SNX-W17
Brief Description:  Right root rib installation
Today I spent some time getting the spar squared up. I used a hinge pin rod as a alignment tool to hang from the top alignment hole to make sure that the wing is vertically strait. I used some small pieces of aluminum as shims under the spar and the some pieces of paper for the final adjustment. I was amazed at how a couple sheets of paper would be all that was needed to move the rod 1/8 inch.
