3/29 1 glued foam on left stub wing 3/30 1.4 removed left gear leg, glued in lower leading edge foam and sanded to contour 3/31 1.1 sanded left upper stub wing to contour and floxed gear leg back on 4/1 5 finished sanding to contour then added fiberglass per the plans with the exception of an extra layer for the wing walk area 4/4 1.5 cut lightening holes on right side ribs and started cutting foam panels 4/9 1 cut/glued more panels for right stub wing 4/10 3 worked on right stub wing and started wiring dynon harness
