Worked the past couple of nights on attaching the vertical spar.
Like everything else, the task takes WAY longer than you would think.
Much time thinking things through, figuring out how the heck I'll get holes drilled in funky spaces etc.. My paws are way too big to stick in certain places and operate a drill or make up bolts and such.
Centered up the vertical spar and drilled the attach bracket and spacer. Primed them, and will assemble tonight.
I'll not be final torking anything just yet. I'll bet I'll be romoving the tail feathers more than one more time before the plane is done.
The angle of the photo makes this look off center, but the VS is parallel to the fuse.
