No work on the RV for the past week. Wiped out with a pretty miserable case of the flu.
Decided to try bending the end tabs again instead of starting out with the riblet concept right away. Glad I did.
When bending the tabs for the trim tab, the smaller size of the trim tab allows you to fabricate the bending blocks with a hook on one end so the blocks don't slide while bending. Works MUCH better! Pleased with the results.
Remainder of the airframe kit is enroute!!! I'll have it in the garage in two days! Woo Hoo!!!!!
