Brief Description: Installed RayAllen grips on control sticks
Bought a nylon tube to take up the space between the metric control stick diameter and the SAE Ray Allen controls stick tube diameter. Feed wire down tube and pushed control switch head over top of tube and control stick (under leather grip and grip foam). Then used a brass tube to hold leather grip apart in threads and drilled and tapped a hole for a set screw to hold the control switch head on the stick and keep it from rotating.
