Davids Pipistrel Build Website
Virus SW 912iS
Installed Cockpit light
Installed seats to check for clearances Marked location and drilled 44mm hole with hole saw. The hole was a little small (needed 45mm). Used dremel to enlarge and make slot for wire. Installed light.
Virus SW 912iS Home
1261
Ailerons
96
Baffling And Cooling
Baggage Area
Brake System
Busses
Center Fuselage
Doors
25
Flight Controls
Forward Fuselage
Fuel Lines
Fuel Tanks
Gear Fairings
Horizontal Stabilizer
Main Gear
92
Nosewheel
Parachute
Parts Preparation
Rear Fuselage
Vertical Stabilizer
Windshield
Wing Tips
Wings to Fuselage
Wiring
