Brief Description: Attached fuel supply line from wing
Drilled out wing pass through plate to accept gromet for fuel line. Installed fuel supply line on wing tank. I had to heat the fuel line quite a bit with a heat gun to get it to side all the way on the fuel tank connector. Used three cable ties to secure. Used a screw driver with the tip on the wide end of the cable tie and a "bent" needle nose pliers (~20 degrees) to grab the free cable tie and and working through the hole in the rib, pried it against the screwdriver to pull it tight.
