ULAY'S WEB SITE
Date:  1-19-2019
Number of Hours:  0.50
Manual Reference:  36-2
Brief Description:  Installing brake lines
Today I made my first major mistate. I misinterpreted the plans and errantly Enlarged the brake exit line hole in Left Main Landing Gear Mount to 5/8". I tried putting the AN837-4D fitting thru the exit hole and it wouldn't go. Without fullyt analyzing the issue, I used my unibit to enlarge the hole to 5/8". Once accomplished I then found out that the hole was now to big to secure the brake fitting properly. Turns out that the hole in the mount should only be 7/16" but due to the powder coating was too small to allow the AN837-4D so all I needed to do was to final drill the hole to 7/16". Now on to the repair!!!!!!
