Painted all the components for the Fuel pump and electrical compartments. Fitted the F894 bottom skin to the fuselage. Drilled the F894 bottom skin to the F891 L&R side skins. Started drilling the Firewall to F894 bottom skin. All stiffners and ribs were drilled, dimpled and primed over a year ago. So I just need to fit the skin and dimple the holes, I'll need to prime the inside of the F894. I'm going to install the insulation to the F890 cabin floor to mitigate heat to the floor. Additinally I'll install sound damping material to the inside of the F894 skin to aliveate any sound from prop and exahust pulses.
