Brief Description: Fuel and Electical Compartments
Riveted all the pieces to gether for the fuel and electical compartments. The Aux bulk heads are done with plate nuts, all the attach angles and stiffners are installed. Installed the plate nuts on both left and right F870 angles. Still need to prime the exterior surface of the covers and the bulk heads. Also drilled out 5 rivets on the right rudder angle that did not set well. Need to drill out one flush rivet on the right side F870 attach angle. Starting the F894 and cooling ramp construction. I'd like to get the lower skin installed with the gear weldments so I can install the brake lines.
