Riveted the bracket to F802 for both L & R. Looked over the Firewall angles and the new fuselage uses a gusset on the mid angle, which adds stability and rigidity to the F801 firewall. I'm going to drill out the two vertical angles and make two gussets and rerivet the F801 vertical angles with the new gusset.
