Removed F802 from the left and right sides to remage the bracket with is riveted to the F891 side skin. The aligment of the drilled holes was not perfect so I remade the bracket and alodined and primed. Also drilled out the bad rivets we did on Wednesday on the F891L skin. Found that I installed the Throtle angle upside down do had to drill out the 15 rivets to turn it over. two steps forward one step back.
