Counter sunk one the one hole which mounts the F804B and F823R to the F889 longeron. I faild to CS this hole on the right side. I also did not drill the same hole on the left side, So I drilled the left and CS the right. I need to CS the left F889 at this position. I fitted the Belly skins to mark the area I need to prime prior to final installation. I'll be shooting primer soon and then final asymbly of the skins to the frame. Found another issue. I dimpled the F826 and F827 and F890 holes near the gear weldment the wrong way. There are 5 holes which need to be dimpled to the outside. I dimpled the F890 correctly but the belly skins were done opposite. So I need to redimple them and hope it doe's not create an issue with work hardining. Additinally I need to remove some material at the gear hole location in the belly skin so the landing gear weldment will clear the belly skin.
