Completed the Elevator bell crank brackets. Preped, alodiened the bell crank and the brackets. Set up and drilled the F-818 ribs for the F8118 bell crank brackets. Drilled out the one rivet in the F808 to F818 which needs to be reset. Parts need to be primed prior to installation.
