started the manufacture of the Elevator Bell Crank bracket, F-8118. I had to use 1X1.5X.125 stock for the angles. This will use up that stock and I'll need to place an order for additional material. shaped the general parts and drilled the pivot hole. Laid out the rivet holes.
