Laid out an oil board to create a template for a new ramp made from 301 or 304 Stainless Steel. I'm not sure if I'll use .016 or .018 but I'm first going to determine the shape and then try to fabricate the ramp. Mounting is a little tricky as access to the lower rivets on the ribs is necessary to mount the side ribs to F890 and mounting F896 to the side rib. So a little though must go into this.
