Worked on the dimpling the belly skin and made a patch for the 3/4" hole at Blukhead F811. Its for the tail wheel and I guess all the tail skins in the past had the hole cut at the factory. So I looked at the plans and the 8A does not use this hole so I made a patch. preped all the skins from tail to F809. I need to counter sink the lower angle then alodine the small parts for the stiffners and prime then I can start the rivet process on the tail skin and start moving forward.
