Well its always something. The F802 will not fit. The holes do not line up with the F890 floor. I did precisly what the manual said about lining up the F890 to the F843 vertex and I'm at least 1 hole diameter off of alignment. Not only that but the skin does not meet the bulk head. What it looks like is the skin has a bulg about in the middle of the bulk head. If I pull this in it may cause a wrinkle of the F891. Thats not right. The dist between F802R's left and right are correct. The F802V aligns with the two bulk heads. I tried to adjust the small flanges on the F802's to get the holes on the F890 to align with some success but still have a big issue with the bulg. Do I shim this so the skin stays nice and smooth? If this doen't fit now what will the problems be in the future?
