Worked on the replacments for F-812. Worked on the Floor bulkhead F-806 and baggage compartment ribs with the floor ribs. Debured and fluted all components. Had to remake F-805D for the left F-814 rib. The drilled hole to match with the existing hole in F814A-L is .032 lower then the top so I had to make a new one to make it work. I used a .030 sheet with the plastic sheet still installed on one site to make up the .002. This was placed bettween the top of the part and the mounting piece. Worked great.
