Brief Description: Elevator Alignment & Rudder Trim
Elevator Alignment -- AN3 hardware should bolt up. Bracket holes are offset 3/16" of an inch. 3/32" high, and 3/32" low... 3/16" total. Hmmm.
Rudder Trim. Plans note 3/4" offset to LEFT (PIC side) to avoid interference with elevator cables. Problem is the rudder is offset for thrust, so the alignment should be offset RIGHT for Avipro QB. Minor issue, pull and flip trim tubes.
