Brief Description: Fuselage Weldments for QB folks
Place holder for Fuselage Weldments.
Thanks to the Bearhawk List when I asked 'what would you add' Easier to think off and list now.
Skylight structure
Electrical subpanel tabs (above foot well) Battery Support Battery Support -- future proof for second battery for IFR/Glass Panel
ELT antenna mount in fuselage top VHF Nav antenna mount in vertical stab Fuel line supports in door post and under front door to meet the 16" support requirement Brke line support (hard metal ends, flexible starts) -- under seats.
Trailing edge of optional aluminum panel under front door Horizontal tube at the front (aircraft forward) end of the radio stack for extra support 4x Seat belt shoulder harness mounting tabs plus extra support tube Support tab for prop control where it meets the panel, including moving the two factory tabs for throttle and mixture
Remade flap handle to new design Cap on top of control sticks to accommodate grips and push-to-talk
Seat headrest provisions and fabricate headrests Headset jack plates (later removed in favor of door jam) Half of an EMT exhaust system Fabricate diagonal brace for oil cooler
Tabs for overhead dome/panel flood lights Landing gear trailing edge mod in case I get bush tires Perhaps fuel valve support, though not for sure
Tabs for Kydex panels in foot well (Pilot/Copilot) and cargo area.
