Began riveting center nose rib into left horizontal stab skin. As much as I tried to put off using the rivet gun as long as possible, it turned out that I had good success and found it to be pretty easy one I got the technique down. Still had to drill out 2 rivets and one ended up being over-sized, so I ordered my first batch of oops rivets from Vans. Wrestled the skin to cleco on the end rib. Riveting the bottom side of the center nose rib was fast and flawless. There's just no way of getting around the learning curve besides rolling up your sleeves and diving in.
