- Removed the air box fiberglass layup from the mold and rough trimmed. A few more layers of fiberglass will be needed to add rigidity - Started adding aluminum angle to the air box mtg frame. This will serve as a place to add a seal and plate nuts to mount the air box. It also helps stiffen up the mtg frame.
