I spent several days and hours working on a filtered air box kit from James Aircraft. The construction was pretty straightforward but the filter housing would not fit with the Van's stock cowling. I could have done some significant modifications to the cowling to make this work but I decided to go a different route.
Please do not make the same mistake I did! Do not try to use the James aircraft filtered air box kit with a Van's cowling. This proved to be a time consuming and expensive mistake. It's a shame I could not use this because I really like the airflow design and filter style.
