- Measured, marked and drilled vertical stabilizer mounting holes per plans - Minor misalignment from stabilizer to fuselage required fabrication of a spacer at the front where the vertical stabilizer mounts to the horizontal stabilizer - Painted and riveted the F-681 Forward Fin Attachment Plate to the vertical stabilzer - Installed the required hardware - Temporarily mounted the rudder to check alignment and fit
