Brief Description: Horizontal stabilizer and elevator
- Installed horizontal stabilizer - Installed elevators to stabilizer - Drilled #12 hole through elevators for pushrod attachment - Attached pushrod with elevator level and control sticks at approximately 5 degrees from vertical - Checked angular movement up and down - Filed areas of stops to achieve 28 degrees up and 22 degrees down of elevator travel
