- Located, drilled, and mounted firewall pass through. Sealed with high temperature RTV sealant at flange and rivets.
Electrical connections for various components (Pmags, temp probe connections, etc) will pass through this SS flange. Once it is coupled with a fire sleeve and sealant, it will create a barrier between the engine compartment and the cabin.
