- Removed pipe plug at inlet port on cylinder #4 - Added stainless steel barbed fitting, high temperature tubing at cylinder connection, flow restrictor (to suppress pulsing effect from the cylinder), and tubing supplied by E-mag - All connections clamped to hose barbs with Herbie clamps - This connection supplies a line to the E-mag to sense intake manifold pressure and adjust spark timing accordingly
