- Removed Bendix retard breaker magneto and ignition wires - Removed drive/timing gear from magneto and installed on E-mag per instructions provided - Installed Emag P-model electronic ignition , PN P114-L4, SN 7097. This ignition will act as the starting ignition utilizing the larger spark gap across the plugs. This will replace the "shower of sparks" generated by the retard breaker magneto and starting vibrator. - Checked ignition wire lengths for reach to assigned cylinders
