If you enjoy using your grinder, this is a fun part to work with! The edges of the vertical stabilizer strengthener piece had very roughly cut edges that need to be smoothed down. The grinder wheel made an easy job of this. I "broke" and rounded the edges a little as well as ground the rough edges down. Just be careful not to go too far with the grinder, it can take a lot off qjuickly if not careful. (No, I didn't have that problem, but just remembered how fast this can remove metal!)
