Brief Description: Just another day of deburring - right H. sablizer
No photos today. All went well for the most part. I completed the drilling of the entire right horizontal stablizer then took it apart. I then noticed that somwhere I missed the step to drill the holes in the end of the middle rib and the rear spar. I then re-attached the skin on the area around that to get a good fit, but only after bending the leading edge tip of the stablizer tip rib. Oops! Fixed that up ok with a little gentle tapping with the bucking bars to get that flattened out as much as possible. Completed the deburring of the skin on both sides. Next time - all the ribs and spars will be deburred. Build on!
