The center bearing for the elevator was next for the rear spar. I clamped the _____ bearing plate in between the ______ and ______ hinge supports making sure the holes lined up. The ____ plat has no holes so I used the other one as a guide to line up the holes. Everything was mounted in the spar so it all lined up properly. First two holes drilled #30 bit, then clekoed the top and did the bottom holes. After deburring they looked fine. All set for priming next then they can be riveted together (probably the first real rivets on the plane too!).
Mountee and ready for hole drilling.
Extra precaution with 2 more clekos in first holes.
