Brief Description: Attaching skin to rudder to fit and drill.
Next step is to attach the skin to the skeleton to match drill all the #40 holes in the skin to the spar and ribs. The only problem I had was a tight fit in a notch where the skin goes around the rudder horn at the bottom front of the assembly. I didn't get a photo of it, but I just used a small file to enlarge the notch for a good fit. I've noticed many other builders have done this on theirs also, so it's normal.
