Traci and Tom's RV-7A
Date:  8-22-2013
Number of Hours:  1.00
Brief Description:  Trailing edge countersink part II
After reading builder forums and seeing what others have done, I realized that I could clecko into wood ok. I match drilled the holes in the wedge through to the wood with a #40 bit. Clekos then held the part on the wood very nicely.
I simply drilled the countersinks again like before and ended up with a nice line of countersunk holes. If some were not even, that's ok. Although mine all ended up nice and the rivet went flush when dropped in the hole.
Clekos held to the board well.
Nice holes drilled.
Nice holes drilled.
