Traci and Tom's RV-7A
Date:  7-29-2013
Number of Hours:  3.00
Brief Description:  Finally riveting the HS-601PP skin to spar.
It took a while again to really get the feel for riveting the skin to the inners of the stablizer. I got the skin attached to the spar and middle ribs. Did I remove rivets? Of course! About 5 had to be replaced. Not stressful at all now, so that' s a good thing.
This is where finding the rigth parts gets critical, but easy to fix if you get something swapped. I clekoed the rib to the skin, then went from there. The tape in the first photo shows duct tape holding the skin This was a good temporary fix to keep the springy skin together.
Got them all in fairly well!
Duct tape to keep the sheet folded.
Smooth rivets.
Smooth rivets.
Scrap foam works well for holding.
