Not too difficult. This was easy to line up and mark the material to remove from the ends of HS-710 and HS-714 spars. 2.5 inches from the end tapered to a 1/2 inch diameter circle at the end around around the hole. I hatched the part to remove, just to make sure I could easily see where I was going.
