Traci and Tom's RV-7A
Date:  5-21-2013
Number of Hours:  1.50
Manual Reference:  Sect 6
Brief Description:  Fitting spars and enlarging holes.
After breaking edges and rounding the ends, it's time to fit the two HS-603PP spars into the front spar HS-702. I used clekos in every third hole since it had a good fit and drilled the #30 holes between the spars and the main spar. Then moved the clekos on hole to the right and did the rest of the holes.
The HS-707 rib will fit behind the 8th hole from the end of the spar, but it takes a #19 hole. So to prevent a problem of a miss-drilled hole, I documented the spar itself to prevent a problem. Distractions halfway through a "measure, count, and re-meaure" could lead to an unfortunatel incident involving a drill. I'll be "idiot proofing" all my work - so get used to it.
Next I placed the HS-413PP and HS-412PP hinges into the spar with clekos and they are ready now for the #30 drilling.
Alternating clekos for positioning spars.
Always
Always "idiot proof" with a Shapie pen!
Fitting hinges and rady for #30 holes.
