Drilled autopilot servo mounting bracket to fuselage elevator bellcrank support. Primed all the pieces and parts and prepared to rivet the bracket. I decided not to drill the bottom flange of the bracket to the bottom fuselage skin, but instead mixed up some epoxy and flox and put a thin layer on the bracket and cleco'd into position. With the extra rivets I put in the side of the bracket, it will be plenty strong. The plans for the servo mounting are not very good, and I'll have to play with the spacers and washers for the push tube to make sure there is no interference.
