Installed the fuel servo, and fabricated a plate to seal off where the snorkel will eventually be attached; installed special fitting on the fuel pump to allow a hose to go to the fuel pressure transducer; installed the starter; hooked up the fuel lines from the pump to the servo, and from the servo to the spider on top of the motor.
