Removed and dis-assembled aileron bellcrank Grease-packed and re-assembled aileron bellcrank Cut the bellcrank spacer for main control bar Assembled the aileron connecting rod (with the limit plate) installed Installed inspection-opening nutplates Prepared, drilled, dimples and primed the inspection-opening covers
