Brief Description: Right Wing - Close up preparation
Deburred and Dimpled the right bottom skins Removed right tank and inspected the joint plate Adjusted joint plate to improve tank/leading edge fit Replaced the Z Bracket nut plates after damaging some Enlarged nutplate holes in the spar to 1/4" to ease the fit of the tank bolts (3 fittings) Tank fitting is now much easier Ready to attach the skins now
