Beginning to fit seat pan and console sides Epoxied clevis pins into mixer assembly to remove some slop. Still need to fabricate and rivet the retention straps. Need to order some shorter mounting bolts for the mixer assembly so they can be installed with heads inboard. This will allow a dab of epoxy at the bolt head to keep it from rotating relative to the mixer assembly.
