Brief Description: Installing the L-Angle by the Horns
Today I finished fabricating the lower control horn and fastened it in place with clecos. Next I attached the doubler through the elevator and clecoed it to both the upper and lower control horns. I then cut and installed L-angles on the left side of the aircraft centerline next to the doubler cutout. Finally I completed marking and drilling the rivet spacing on the top and bottom of the elevator center channel and hinge line.
