TIMOTHY'S WEB SITE
Date:  2-11-2018
Number of Hours:  3.50
Manual Reference:  SNX-F26/SNX-F25
Brief Description:  Match Drilling of Longerons to Aft Fuse Side Skins
Made 14 degree bend at forward end of each Aft Fuse side skins. Position upper & lower Longerons to both RH and LH Aft Fuse side skins and match drilled holes in the longerons with the pre-drilled holes in the skins.
14 Degree Bend on Aft Fuse Side Skins.
Upper Longeron Match Drilled on RH Aft Fuse Side Skin.
Upper & Lower Longerons Match Drilled on RH Aft Fuse Side Skin.
