Brief Description: Cut and bent trim tab hinge pin
Cut and bent the trim tab hinge pin. Drilled small (#40) hole into trim spar to fasten the hinge pin with safety wire (not yet done). Bent E-919 (bottom trim tab skin fwd of trim tab spar) slightly upwards to clear bottom elevator skin.
