Brief Description: Drilled elevator horn, continued with fairing work
Drilled the centre hinge attachment hole for both elevator horns. Used a drill bushing that a colleague from work milled with a lathe. Thanks. Worked out fine, drilled the pilot holes to 1/4". Continued work with the rudder bottom fairing.
