Adjusted the length of the elevator rod end bearings. The left elevator is OK, the right still needs some adjustments. Started cutting the HS tips. Cut the aft edge flush with the elevator counterbalance horn, not realizing that the elevator fairing tapers aft. Argh! Corrected that on the second HS tip fairing, still unsure what to do with the first one.
Next: Finalize setting of rod end bearings on right elevator, continue on empennage tip fairings.
